mdewyea
Posted: Sat Mar 28, 2009 1:18 pm Post subject: Welds not turning red |
| When Im in UV view and after i flatten the geomtry when i click the edges to weld them there not turning red...any help to fix this would be appreciated |
Posted: Sun Mar 29, 2009 6:46 pm Post subject: |
You need to use the "W" key on the keyboard instead of clicking the mouse.
jaylee81
Posted: Thu Dec 09, 2010 6:24 am Post subject: welding not working in osx |
Hi I'm testing the demo version in osx and now I'm having problems welding.
The seems won't turn red (they only turn yellow) when I'm holding the w-key and pointing with the mouse, I'm not clicking. Then I can't weld them from hitting return, and nothing happens when i tap the m-key to stick the parts together.
Is this a bug in osx run through x11 or am I doing something wrong?
The program looks great so I hope I can get this working
Thanks!
/Johannes |
Posted: Thu Dec 09, 2010 6:03 pm Post subject: |
If seams are turning yellow it means that the other edge is on a face that hasn't been dropped into UV space yet. If you look at the image below, the yellow edges are on the flattened shell (seen with texture in the 3D view), but the shell that I was trying to weld too hasn't been flattened yet ... its got no texture, and would be found floating in the "Ed" space still.
jaylee81
Posted: Fri Dec 10, 2010 4:11 am Post subject: Got it working |
Thanks Phil!
I had missed the flattening step when I dropped it to UV mode, and now it's working.
Cheers!
/Johannes |
