Can you use uvlayout then only export the uvw map out
designzoo
PostPosted: Wed Nov 17, 2010 3:58 pm    Post subject: Can you use uvlayout then only export the uvw map out Reply with quote
My problem is that i've got a model which is already rigged & animated and i want to use uv layout to quickly map the model then export the uvmap back into 3dsmax for the other model.
Is it possible to export out only the uvw map out after i've finished mapping the object.
and if so how do you do this.
G
PostPosted: Wed Nov 17, 2010 5:51 pm    Post subject: Reply with quote
You should have a look at the max plugin ...
Its makes it easier to move data between UVLayout and Max, and I think it updates the UVs on the loaded object, which is the sort of thing you are looking for.
