berndr
Posted: Thu Aug 12, 2010 5:29 am Post subject: Problems Loading |
I ve updated to Windows 7 .. and now Uv layout stopped working ...
i tried countless time to reinstall it ... bit nothing worked not even playing with compatibility settings...
every time I tried to open an obj file
I keep getting little red error box \\\\\PROBLEM LOADING NO SUCH FILE OR DIRECTORY,,,,,,
please help
thanks
Beri |
Posted: Thu Aug 12, 2010 4:50 pm Post subject: |
Run the licensing GUI, which you can get to by clicking "About UVLayout" at the top of the main UVLayout window. There should be a Test button, which will load a standard torus into UVLayout. Does that work?
berndr
Posted: Thu Aug 12, 2010 5:45 pm Post subject: |
Thanks for the reply Yes that works, but nothing else does
I cant open anything
any idea? |
Posted: Thu Aug 12, 2010 6:11 pm Post subject: |
OK, can you grab a screen shot of the error?
When loading an OBJ (as opposed to the test torus) UVLayout is running a separate program to convert the file, so it could be that its having problems either finding or running that program, or there might be an issue with the temporary file that's created by that other program.
Back in the licensing GUI, click on "Common Preferences". Click on the arrow next to "Temp Dir" and select a folder that you know for sure that you can write to, then restart UVLayout and try and load an OBJ.
