legacyeffects
Posted: Fri Jun 04, 2010 6:59 am Post subject: Vista |
Trying to use the trial and every time I import an OBJ I get an error that says 3d Applications Core has stooped working. This happens in Professional & Hobbyist
Can you advise?
Thanks |
Posted: Fri Jun 04, 2010 6:06 pm Post subject: |
There was a problem with the Demo that I fixed a couple of weeks ago. If you downloaded yours before the 20th of May, then grab it again and that should fix the problem.
Otherwise, is it one specific OBJ file that causes the crash, or every one you try to load up?
m2
Posted: Sun Aug 22, 2010 7:31 pm Post subject: |
I am also getting this error. It happens with every OBJ I try to open with UVLayout, even ones that previously worked.
I had just downloaded the newest demo as well. It crashes when loading the Seams. |
Posted: Sun Aug 22, 2010 7:36 pm Post subject: |
Which version of UVLayout are you running?
Also, are you running over multiple monitors with an nVidia graphics card? Some people doing that have problems, but a driver upgrade usually fixes it.
m2
Posted: Sun Aug 22, 2010 7:42 pm Post subject: |
Thanks for the quick reply!
I uninstalled and reinstalled and it appears to be working now. I may have started installing the new demo before the old copy was done uninstalling. |
Posted: Sun Aug 22, 2010 7:48 pm Post subject: |
"and it appears to be working now"
Great!
cristobal
Posted: Tue Aug 02, 2011 9:00 am Post subject: |
| headus wrote: | "and it appears to be working now"
Great!
I did the same and am happy to know that I was not the only one....
It's working perfectly for me now.
Thank you for posting!
E. Cristobal |
3dmaxpro
Posted: Wed Oct 12, 2011 2:47 pm Post subject: |
| One thing that I also noticed it helps too to install to C:/ instead of into program files because then you don't have to worry about the UAC from effecting the program. Cause on windows 7 UAC is a pain in the butt sometimes you have to turn it down twice for it to apply. |
