W key not welding
stezza
PostPosted: Mon Mar 08, 2010 7:55 am    Post subject: W key not welding Reply with quote
Very odd, the W key has stopped functioning to weld my edges (no red edges), but I can cut ok.
Any ideas?
View user's profile Send private message MSN Messenger
stezza
PostPosted: Mon Mar 08, 2010 10:49 am    Post subject: Reply with quote
OK the W key does weld but there is no red edge selection, if I W and edge then press enter it does join but is a real pain aligning shells if you cant see the selected edges.
PostPosted: Mon Mar 08, 2010 5:02 pm    Post subject: Reply with quote
Has anything changed on your system recently, like an OS upgrade or new graphics card or driver?
Also, what version of UVLayout are you using?
And finally, if you pan the camera, do the red edges appear on the redraw, or are they still invisible?
stezza
PostPosted: Tue Mar 09, 2010 1:36 am    Post subject: Reply with quote
I did have a new ATI V5600 graphics card installed some time ago but I'm sure I have use UVL since it's installation.
UVL version is V2.06.02
The red selections do appear in 3d view, it's just the UV window thats the problem.
I will re-install just to make sure.
S
