Move to weld preview
PostPosted: Sun Feb 21, 2010 2:08 pm    Post subject: Move to weld preview Reply with quote
Here's one to chew on.
What if, similar to the way the fast weld or Shift-M works UVL could look at multiple edges and position them for auto welding. There would most likely need to be a preview, and the option to continue with the weld.
Sound do-able?
M
PostPosted: Sun Feb 21, 2010 5:25 pm    Post subject: move and weld update Reply with quote
This little video and image shows the type of mesh and how I am approaching this particular task. It's not much fun mate.
Can you think of a good/better way to approach it?
Worth mentioning is that the geometry is not all the same so copying doesnt seem to work in this instance.
M
PostPosted: Sun Feb 21, 2010 5:30 pm    Post subject: geo Reply with quote
here a sample of the geo
PostPosted: Sun Feb 21, 2010 6:09 pm    Post subject: Reply with quote
I'd be tempted myself to replace the geometry. I looks like something has triangulated all N-sided polys into quads ... I don't think UVLayout is doing it. Maybe if you can find the thing that's doing that, and turn it off, your life will be a little easier.
Anyway, if you had cleaner geometry you'd have much better luck with Copy UVs, and probably the welds too, and anything else I write to automate things based on matching topology.
PostPosted: Sun Feb 21, 2010 7:39 pm    Post subject: shyte Reply with quote
Yes. That is some rather bad geometry.
I seem to be testing UVL's ability to unwrap shyte meshes.
