johanz128
Posted: Sat Feb 13, 2010 6:31 am Post subject: uvlayour freezes often |
Every time I hold F to map mesh, it freezes.
Actually only cyeatP.exe freezes. If I end it, I can use it again, but all my work is gone and if I do it again, it freezes again |
Posted: Sun Feb 14, 2010 5:35 pm Post subject: |
Which version of UVLayout on which OS are you running?
johanz128
Posted: Mon Feb 15, 2010 3:37 am Post subject: |
| I use 2.06.00 on XP sp3 32 bit |
Posted: Mon Feb 15, 2010 3:45 am Post subject: |
The latest release is v2.06.02, so I'd install that first to see if it helps. Some of the 2.06.00 beta releases were broken, so you might be running one of those.
twocust
Posted: Tue Feb 16, 2010 2:40 pm Post subject: |
many versions ago there were issues with video drivers and multiple monitors...
perhaps this might be a consideration as well, johanz128 (not sure whether
you run UVLayout with mult. monitors)
my solution was to revert back to older drivers (which was tricky due to using
a laptop with minimal vid card driver updates) |
johanz128
Posted: Fri Feb 19, 2010 8:33 am Post subject: |
Updated to latest ver, still freezes.
And no I don't run double monitors. And also I can't revert back to older drivers because I like gaming too. |
Posted: Fri Feb 19, 2010 7:24 pm Post subject: |
What happens if you LMB select the shell then click on the Optimize "Run For" button? It runs the exact same bit of code as the 'F' key, so if it works you at least have a work around until we work out whats wrong with 'F'.
