Cant get the demo to work
danfitchie
PostPosted: Sun Nov 15, 2009 9:44 am    Post subject: Cant get the demo to work Reply with quote
Im trying to well try out the demo available on the website but am having troubles getting it to work. After installing it and then opening it, it just says expired and suggests downloading a newer demo. Im using the installer available on the main website so am rather confusedl
Any ideas?
PostPosted: Sun Nov 15, 2009 6:55 pm    Post subject: Reply with quote
Is the date correct on your PC?
danfitchie
PostPosted: Mon Nov 16, 2009 2:29 pm    Post subject: Reply with quote
Yes the date is right on my pc, strange isnt it. The demo says it expires on the 19th Dec or something but it just says expired....
PostPosted: Mon Nov 16, 2009 6:06 pm    Post subject: Reply with quote
OK, try this ...
Use "Setting->Add/Remove Programs" to uninstall the demo, completely removed the "Program Files\headus UVLayout v2 Demo" folder, and completely remove the "Documents and Settings\<your login>\Application Data\headus" folder too. Also remove any Demo installers you currently have, then re-download and re-install.
danfitchie
PostPosted: Tue Nov 17, 2009 1:29 am    Post subject: Reply with quote
thankyou phil, ill give it a try and let you know!
