how to get a larger rendered image?
robn
PostPosted: Thu Sep 10, 2009 6:03 am    Post subject: how to get a larger rendered image? Reply with quote
Is it possible to get a larger rendered image out of uv lay-out. When you have several forms in one image they become each very small..
Rob
PostPosted: Thu Sep 10, 2009 5:17 pm    Post subject: Reply with quote
Are you clicking on the arrow to the right of "256" in the Render panel? It'll go up to 4k, which is 4096 pixels square for the output map.
robn
PostPosted: Thu Sep 10, 2009 5:49 pm    Post subject: Reply with quote
thank you, that is musch better. Only I don't see edges in the rendered figure .I see just some pixels. I cheked "AA lines" and "fill poly's"
PostPosted: Thu Sep 10, 2009 6:01 pm    Post subject: Reply with quote
The image viewer that runs after the Render will show the whole map by default, so if you've selected "4k" then edges could be disappearing because the image is zoomed down so you can see it all. Use the "1" hotkey key in the image viewer to zoom in, or re-render at 1k maybe.
robn
PostPosted: Fri Sep 11, 2009 6:22 pm    Post subject: Reply with quote
Thanks, I discovered that 512 is the best option . It gives quiet a large picture and you can see the edges .
