robn
Posted: Thu Sep 03, 2009 4:15 pm Post subject: how to weld several pieces together in uv mode? |
How can I weld several pieces together in uv-mode ? In the last video-tutorial (about the symmetry tool) it seemed to be done just with "enter" but that doesn't work here
So I guess there is another short cut combination for this?
Thanks,
Rob |
Posted: Thu Sep 03, 2009 5:54 pm Post subject: |
"Enter" should be welding, but you also need to tag which edges actually get welded first. Aim the mouse pointer at an edge, tap "W" and it'll turn from green to red, then Enter over that shell will weld the edge. Check out the "Welding-Shells" video for more details.
