Preserve the hierarchy on import/export.
Rich-Art
PostPosted: Sun Jun 28, 2009 11:22 am    Post subject: Preserve the hierarchy on import/export. Reply with quote
I would love to see an option to preserve the hierarchy on import/export.
When I Export a file from C4D to OBJ format, the objects are separate.
I open the file in UVL, do the UV stuff and save the file.
Now when I import the file back in Cinema4D, all the separate objects are combined in one poly object.
I would love to see UVL saves the file as it was opened, ea with the hierarchy intact.
See attachment.
On the left before the export in Cinema4D.
On the right after the UV's are done in UVL and imported back to C4D.
You see that all the separate objects are imported as 1 poly object.
Normally when I export and import the hierarchy is preserved. Only when I save in UVL and import this into Cinema4D I see this behaviour.
Peace,
Rich_Art. Wink
PostPosted: Sun Jun 28, 2009 5:44 pm    Post subject: Reply with quote
Have you tried the "Update" button instead of the usual "Save"? You select the original OBJ file, then UVLayout makes a copy and modifies it with the new UVs, leaving all the other information intact.
Phl
Rich-Art
PostPosted: Sun Jun 28, 2009 10:46 pm    Post subject: Reply with quote
Thanks. I totally forgot the update function. With the update instead of save, the hierarchy stays intact indeed. Cool....
Peace,
Rich_Art. Wink
PostPosted: Mon Jun 29, 2009 1:38 am    Post subject: Reply with quote
I do hope to someday fix it so there's just a "Save" button; it'll preserve the materials/grouping info automatically without having to select the original OBJ.
Rich-Art
PostPosted: Mon Jun 29, 2009 2:05 am    Post subject: Reply with quote
Sounds cool although now that I know I must use the update button it is fine as it is now. at least for me it is. Smile
Peace,
Rich_Art. Wink
