r10k
Posted: Wed Mar 18, 2009 6:33 am Post subject: A couple of packing questions... |
During packing, is there a way to stop boxes packing into other boxes? I notice normal non-boxed items don't join the box, even if it's packed into the box's area, but other boxes do.
I have a model's UV's that apparently take up 126% of UV space. There's nothing outside of the 0-1 UV space, and the UVs take up about two thirds of the space, so... is this a bug?  |
Posted: Wed Mar 18, 2009 5:30 pm Post subject: Re: A couple of packing questions... |
"I notice normal non-boxed items don't join the box, even if it's packed into the box's area, but other boxes do."
Hmmm, you are correct ... that does seem inconsistent, doesn't it! Normally items are only added to a box when they're drag'n'dropped into the container, but it looks like smaller boxes are being "captured" during the packing process. Maybe I thought it was a good idea at the time?
There's no way to stop this happening unfortunately. I'll have a go at fixing that next week sometime.
"I have a model's UV's that apparently take up 126% of UV space."
Do you have any shells stacked on top of each other?
r10k
Posted: Wed Mar 18, 2009 5:36 pm Post subject: |
| Quote: | | I'll have a go at fixing that next week sometime. |
Awesome, thanks
| Quote: | | Do you have any shells stacked on top of each other? |
I do, and I did think this morning that stacked shells might be the cause, but listing amounts over 100% isn't correct, is it? After all, the stacked shells are occupying the same space, not any additional space. |
Posted: Wed Mar 18, 2009 5:50 pm Post subject: |
"I do, and I did think this morning that stacked shells might be the cause"
OK, thanks. I just wanted to check on the most likely cause, and you're correct, its probably not right to show over 100%. Hmmm, maybe I'll show both though, because if you're stacking you might want to know the space saved???
r10k
Posted: Wed Mar 18, 2009 7:44 pm Post subject: |
Hehe... that'd be interesting  |
