paqwak
Posted: Sun Sep 28, 2008 12:21 am Post subject: Split Edge dont split ! (demo 2.3 in pro mode) |
Here's a little bug I want to report :
Ok here's the stupid object
I split the front part using the G command, then ENTER
THen I select this edge loop, to cut the body part in 2 pieces,
I'm using the SHIFT S command.
Visualy, the model seems to be splited, but it's still physically attached when I want to move a part of it.
If I use the ENTER key instead the SHIFT S command, the object is correctly splitted !
Hope the description is clear enough
Little update,
Even if I can't move the 2 parts in the edit view, I can drop (D) the 2 pieces one by one in the uv edit view ... and the flattening process works perfecly. However if I drop the complete objet at once (D + draging the selection rectangle over everything) ->
Well it's a mess ->
Posted: Sun Sep 28, 2008 2:53 am Post subject: |
Thank you for reporting the split bug! Its quite a basic one, and I'm amazed it hasn't turned up before, but I can easily duplicate it here.
I shall fix that for the next release, but in the meantime you can use Enter instead. It can now be used to both split and detach, and in fact Shift-S for splitting is no longer required.
As for the flattening mess you see there, I'm not sure how that's happened. I suggest using Enter for the split and see how you go after that.
paqwak
Posted: Sun Sep 28, 2008 3:03 am Post subject: |
| Cool to hear for the fix, and yes the mess from the last picture don't happend when I split the objet using the [ENTER] key. |
Posted: Sun Sep 28, 2008 3:17 am Post subject: |
Thanks for the update! What I'll probably do is remove the old Shift-S function (which is obviously buggy), and will just remap it to do exactly what Enter now does.
