UVguy
Posted: Mon Sep 22, 2008 5:04 am Post subject: can you connect to USB dongal over a lan? |
I am running out of USB posrts what with usb mice, keyboards, tablets, external drives , other dongals etc etc etc....
is there a way to have the dongal attached to one of the servers and connect the uv layout software to it though the lan? |
Posted: Mon Sep 22, 2008 5:12 pm Post subject: |
Yes, but you'd need to upgrade to a floating license. The dongle (and some software) would sit on the server, then anyone on the LAN (as long as its one at a time) could use that license.
Or you could just get yourself a USB hub. These take up one USB port but usually give you four more free ports. Some need external power, but others will happily run off the USB port itself.
UVguy
Posted: Mon Oct 06, 2008 12:52 pm Post subject: |
| headus wrote: | | Or you could just get yourself a USB hub. |
USB hub worked fine.. AND i do not have to "trust" my dongel into the server room.
Thanks for the tip.. didn't even know these things existed. |
Posted: Mon Oct 06, 2008 6:32 pm Post subject: |
"USB hub worked fine.. "
Great!
Thanks for the update.
