andrerisse
Posted: Wed Aug 20, 2008 8:33 pm Post subject: Unable to cut poly |
Let me apologize for taking up your time. But I have another problem. This is a section of a roof I am building. I downloaded one half of it into UV Layout. My problem is I cant cut the edges and upon download it turned up a blue color in the center portion of the roof.
thanks again for your help,
andre |
Posted: Thu Aug 21, 2008 3:24 am Post subject: |
Polys are shaded blue on the inside in UVLayout.
Whats happening on your roof panel there is that the central poly has backwards vertex ordering; instead of clockwise, its counter-clockwise. The blue dashed edge around it is also an indication of this incorrect topology.
You can only fix this in your modeling application. There might be a tool to "Unify" normals, or even just display the normals, then select that face and flip the normal so its pointing outwards.
andrerisse
Posted: Thu Aug 21, 2008 8:58 am Post subject: |
once again thank you
Andre |
