andrerisse
Posted: Wed Aug 20, 2008 3:47 pm Post subject: uv texture |
After completing the uv process and putting a headus numbered texture on the object, and then importing the object back into Maya, does the headus numbered texture show up in Maya? Or is there another way to ckeck that the new uv's imported correctly?
thanks,
andre |
Posted: Wed Aug 20, 2008 5:16 pm Post subject: |
"does the headus numbered texture show up in Maya?"
No, its a texture built in to UVLayout itself; you can find the TIF file in the UVLayout install folder, so could copy it out of there for use in Maya if you want.
"way to ckeck that the new uv's imported correctly?"
Open up Maya's UV texture editor to see if they look like they did back in UVLayout. You could also map a checker texture onto the object to see how it looks rendered.
