possibility to set default path?
spot
PostPosted: Thu Jul 24, 2008 5:07 am    Post subject: possibility to set default path? Reply with quote
is there any possibility to set default paths in uvlayout? so i can set my project folders i'm working in instead of having to point the file browser (load/save) everytime i open it.
PostPosted: Fri Jul 25, 2008 5:27 pm    Post subject: Reply with quote
Normally if you drag'n'drop an OBJ or UVL onto the UVLayout desktop icon, that sets the path for file browsing for that instance of UVLayout.
If you're running UVLayout from the Start Programs menu, then right click on the "Run UVLayout" option, select "Properties" and set the "Start In" field to the folder you want.
spot
PostPosted: Sat Jul 26, 2008 2:33 am    Post subject: Reply with quote
thanks! since i'm not a big fan of desktop clutter and drag'n'drop, i start the uvlayout program through the quick launch menu. the tip with the "start in" setting works fine for me. but i'd still like to propose this as a feature request Smile. anyways, thanks for the great support, as always.
PostPosted: Sun Jul 27, 2008 4:53 pm    Post subject: Reply with quote
Request noted! Actually, I've been wanting to add a "most recently visited" history to the file selection dialogs too, so that would also help in this situation.
PostPosted: Fri Aug 08, 2008 12:42 am    Post subject: Reply with quote
OK, have a look at the latest update ...
http://www.headus.com/phpbb/viewtopic.php?p=3122#3122
You can now set a "Home" folder preference for non-drag'n'drop start-ups of UVLayout.
spot
PostPosted: Mon Aug 18, 2008 8:24 am    Post subject: Reply with quote
thanks a million times to take care about my request!
