error when run on Fedora 8
uwaterlooo
PostPosted: Thu Jun 05, 2008 1:53 pm    Post subject: error when run on Fedora 8 Reply with quote
HI, I install the newest version 2.1 beta~on Fedora 8
and when I try to run UVL, it gives me an error like this ..
(sh: cysliceD: command not found)
so plz help me~ Shocked
PostPosted: Thu Jun 05, 2008 4:54 pm    Post subject: Reply with quote
Its looking like the uvlayout demo install folder isn't in your execution path. The instructions are for csh type login shells (eg tcsh), so you may need to adjust those to work with others (i.e. bash).
uwaterlooo
PostPosted: Thu Jun 05, 2008 10:58 pm    Post subject: Reply with quote
Hi, thanks, but what command should I type in .bashrc?
I dont know how to thansfer tcsh command to bash.....
edit:
I add two lines in bashrc
(export HEADUS_HOME=/usr/local/uvlayout-demo)
(export path =${HEADUS_HOME}/bin)
but no lucky to run uvlayout..........
PostPosted: Thu Jun 05, 2008 11:38 pm    Post subject: Reply with quote
The csh/tcsh setup code is ...
Code:
setenv HEADUS_HOME /usr/local/uvlayout-demo
set path = ( $HEADUS_HOME/bin $path )
...and the bash code is ...
Code:
export PATH=$HEADUS_HOME/bin:$PATH
uwaterlooo
PostPosted: Thu Jun 05, 2008 11:45 pm    Post subject: Reply with quote
wow great! Laughing it seems like i need to use capital PATH
thank you.
PostPosted: Thu Jun 05, 2008 11:49 pm    Post subject: Reply with quote
No problems ... actually, I should have had this in the docs anyway!
uwaterlooo
PostPosted: Thu Jun 05, 2008 11:50 pm    Post subject: Reply with quote
oh one last thing, how can i make a shortcut on desktop to run uvl?
I need to type command in console to run uvlayout everytime for now.........
PostPosted: Thu Jun 05, 2008 11:56 pm    Post subject: Reply with quote
It depends on which desktop manager you're using. I'm very much old school, and do everything under Linux from shell windows, so actually don't know how to set up a desktop icon/shortcut anyway :-) A google search should give you plenty of help there.
