hard edges on re-import
rem7
PostPosted: Mon Apr 21, 2008 7:16 am    Post subject: hard edges on re-import Reply with quote
Hi. I just started using UVLayout, Awesome tool. I have a question tho, after I do my UV Layout and I bring the obj back to Maya my edges are hard. Is there a way to change this? I've looked all over the forums and didn't find anything.
Here is what I mean, with pictures Smile
before exporting:
importing after UVLayout (notices the hard edges)
PostPosted: Mon Apr 21, 2008 4:32 pm    Post subject: Reply with quote
Use the "Update" button to save your mesh out from UVLayout. You select the original OBJ file saved out by Maya, then it creates a copy of that with the original materials and smoothing information, but with modified UVs.
The "Save" strips out all material and smooth information.
rem7
PostPosted: Mon Apr 21, 2008 8:07 pm    Post subject: Reply with quote
I knew it had to be something simple like that. Thanks Phil!
Tenchi
PostPosted: Tue May 06, 2008 7:05 am    Post subject: Reply with quote
my thanks as well Phil... I've been stumped for the last 20mins!
