Multiple .obj's on a single map?
MayaMike
PostPosted: Fri Mar 07, 2008 6:12 am    Post subject: Multiple .obj's on a single map? Reply with quote
I was wondering if there is a way to bring in my model as well as the accessories, in order to place on a single map, without combining it all in a single .obj?
In the past I would have to do this but i was wondering if there is a workaround?
Any help would be appreciated, thanks Very Happy
PostPosted: Fri Mar 07, 2008 4:34 pm    Post subject: Reply with quote
No, sorry, no work-around. Currently UVLayout only supports single OBJs for import and export.
Just confirming what you want ... to be able to load multiple OBJ files, flatten the pieces as you normally would, then the Save/Update buttons would write the results back out into those separate OBJ files, right?
MayaMike
PostPosted: Fri Mar 07, 2008 8:28 pm    Post subject: Reply with quote
Thanks Phil, for replying so quickly.
In regards to my question, its totally fine. It was just curiosity more than anything Smile
