Ugebber
Posted: Sat Feb 23, 2008 11:23 am Post subject: Scale up brush/texture problem on 20005 |
Hi, I can't scale up textures or brush size with this version. The reduce button seems to work (-) but the enlarge don't which is (=) and requires a combination of shift key+ 0 key.
I was working with 20003 and was working alright but updates it recently. Should I return to 03? and in that case a simple uninstall should work?
Thanks. |
Posted: Sat Feb 23, 2008 4:43 pm Post subject: |
Yes, an uninstall of the new version and a re-install of the older one is the right way to down-grade. I'm curious to hear how that goes though, because my first thought was that you keyboard mapping has changed, and not uvlayout.
Ugebber
Posted: Fri Feb 29, 2008 11:22 pm Post subject: |
Thanks for the quick reply Phil!
No, I hadn't changed keyboard or something so I checked that the problem was still there first then uninstall 20005.
Re installed 20003 and to my surprise the problem was still there! so I remove it and then leave it for a day or so.
Reinstalled 20005 later just to see and now the scale works as usual. Yeah, very odd.
So no biggie but was a little strange since I hadn't have a problem since the early beta era.
Could it be possible that the installation of another application could have caused this instability in my system?
Thanks again! |
Posted: Sat Mar 01, 2008 5:29 pm Post subject: |
"No, I hadn't changed keyboard "
What about the keyboard language/layout? If its set to German for example, then that will change what some of the keys produce when typed.
