what should I do in case of flapping faces
isaac_cm
PostPosted: Tue Jan 15, 2008 8:18 am    Post subject: what should I do in case of flapping faces Reply with quote
hello I tried to flattened the mouse but it keep flapping on some edges (see pic)
I tried to set point and anchors but I need to understand when to use them and what is the difference between green points and fuchsia points ?
Please advice.
Thanks
Andreseloy
PostPosted: Tue Jan 15, 2008 1:53 pm    Post subject: Reply with quote
Use Ctrl+MBM to move overlapping vertices
s=mark poly(green)
p=pin vertices(fucsia)
Please see the video Pinning Points
Andreseloy
PostPosted: Tue Jan 15, 2008 4:37 pm    Post subject: Reply with quote
You might want to also look at Webbing ... its covered in the Split-and-Stretch movie. You could use it to stop that inner hole from collapsing.
isaac_cm
PostPosted: Wed Jan 16, 2008 5:05 am    Post subject: Reply with quote
Thank you all guys for wonderful help , really appreciated
PostPosted: Wed Jan 16, 2008 5:25 pm    Post subject: Reply with quote
Actually, the Head tutorial is probably a better series of movies to watch if you want to know more about webbing.
