I cant cut some faces !!
isaac_cm
PostPosted: Mon Jan 14, 2008 12:25 pm    Post subject: I cant cut some faces !! Reply with quote
In the head tutorial when I tried to cut the mouse I get a red line after pressing enter and also the nose holes they are not symmetrical so I placed a cut on both holes but only one is cut and red line on the other one.
please advice.
thanks
Andreseloy
PostPosted: Mon Jan 14, 2008 2:55 pm    Post subject: Reply with quote
press shift+s
Andreseloy
isaac_cm
PostPosted: Mon Jan 14, 2008 3:14 pm    Post subject: Reply with quote
I got no splits found!! please also tell me the following:
- What is the meaning of read line after pressing Enter.
- When I use Shif+S and when I use Enter ???
I think I should use Shift+s only if I dont to completely pullout the hole part, right ?
PostPosted: Mon Jan 14, 2008 4:18 pm    Post subject: Reply with quote
"What is the meaning of read line after pressing Enter."
Most likely a small gap in the cut line. It has to be a closed loop for the cut to work, so use the Home hey to focus on that area and zoom right in to see if you can find the gap in the cut line.
If you cant find the gap, you could use the G key as an alternate method for detaching those polys ... hold down the G key to green paint the polys on the inside of the nose, then use Enter to detach that section.
"I think I should use Shift+s only if I dont to completely pullout the hole part,"
Shift-S is for cutting a split/dart into a single piece, where the detach Enter is when you want to cut the piece into smaller pieces.
isaac_cm
PostPosted: Tue Jan 15, 2008 8:09 am    Post subject: Reply with quote
Home key WOW.
I fond a two pixel edge is not highlighted when I pressed enter that was making the problem, please make the tool to display a message if the cut is not complete after pressing enter.
Thanks
PostPosted: Tue Jan 15, 2008 4:50 pm    Post subject: Reply with quote
"please make the tool to display a message if the cut is not complete"
Actually, thats probably a good idea. I'll look into it.
