Question about the edit menu
spongebob
PostPosted: Mon Nov 12, 2007 6:29 pm    Post subject: Question about the edit menu Reply with quote
When I reopen my file, I have to chose edit instead of new. When I open with edit options, I am not able to us the edit menu, but only UV, and 3d view. Does anyone know how to reenable the edit menu? Bobby.
PostPosted: Mon Nov 12, 2007 7:12 pm    Post subject: Reply with quote
The "Ed" view/mode is only used for the initial cutting up of the mesh before its dropped into UV space and flattened out. If you load your object with existing UVs, then usually nothing will be unflattering so the "Ed" view is disabled (it would be empty anyway).
If you want to reposition seams, you can use the C and W hotkeys in both the UV and 3D views, or you Shift-D undrop shells and they'll go back into the "Ed" view. This is covered in the "UVLayout-Undropping-Shells" video under the "Basic" videos at www.uvlayout.com.
