Anhslaught
Posted: Wed Aug 08, 2007 4:05 pm Post subject: Can't open in maya. |
I'm using the latest Headus right now.
Window build: 2007/08/03.
first problem, it keeps crashing over and over and over so I had to save everytime i flatten one part.
I finished mapping it out. I saved it as out as file.obj.
Tried to open it in maya, but it doesnt appear.
The only thing that appears in maya, which is in the outline editor is an object file
that reads headusOBJexport.
That's the only thing that appear, it has no data in it.
How do I open or fix this? |
Posted: Wed Aug 08, 2007 5:37 pm Post subject: Re: Can't open in maya. |
" it keeps crashing over and over and over "
Do you get any error messages?
Anhslaught
Posted: Wed Aug 08, 2007 10:50 pm Post subject: |
nope, no error messages in maya. I figured it might have been missing a shader, so I selected it in the outliner, but it doesn't even show up. |
Posted: Thu Aug 09, 2007 12:05 am Post subject: |
No, sorry, I meant does UVLayout give any error when it crashes?
Anhslaught
Posted: Thu Aug 09, 2007 2:36 pm Post subject: |
headus wrote: | No, sorry, I meant does UVLayout give any error when it crashes?
I didn't get any error messages when it crashed. It just closed the working window, and the tool menu stays there.
as for importing it into maya, only thing you can see are the uv layouts, no models. :/
I'm going to try and go back one version to see if it helps. |
Anhslaught
Posted: Thu Aug 09, 2007 4:54 pm Post subject: |
Seems that I need to take parts of my model in at a time to unwrap. It doesn't work at all when I put my whole model in. Plus, even with the pieces, it still doesn't work sometimes. It's really frustrating. Which one is the best working version? |
Posted: Thu Aug 09, 2007 5:11 pm Post subject: |
Can you email me one of your OBJ files? Its sounding like there's something in them thats causing UVLayout to crash.
Anhslaught
Posted: Thu Aug 09, 2007 6:55 pm Post subject: |
Yeah sure, I'll send you my OBJ file. I found a way around this, but it is extremely time consuming. Instead of clicking the numbers to save my progress, I click save, and save it as a obj file. I give it a number everytime I save it, if it crashes, I know it doesn't work in maya. If it doesn't crash, it works. I do it step by step so that I know what works and what doesn't. Anyways im using the 3rd version from the latest, and each time it crashes, it gives me this :
"uvlayout v1.20.3 2007/07/23 15:49:41
Fatal error detected! Stack dump follows:
5790e9c2 6db0aaf2 77d4dae2 13a3c9f1 64b0daf1 77d5afe2
12d6c9f0 11b0d8f2 77d5afe2 66a0c987 11b0ac84 77d5aae2
12d3c9f7 14b0dc81 77d5afe2 12d6c9f6 6fb0de81 6db0aaf2
77d4dae2 13a3c9f1 64b0daf1 77d5afe2 12d6c9f0 11b0d8f2
77d5afe2 66a0c987 11b0ac84 77d1aae2 16d3c9f3 14b0d881
77d1afe2 16d6c9f2 6fb0ab81 6db0aaf2 77d4dae2 13a3c9f1
64b0daf1 77d5afe2 12d6c9f0 14b0d8f1 77d5aae2 66a3c987
14b0ac81 77d1afe2 16d6c9f3 11b0d884 77d1aae2 16d3c9f2
15b0ab84 6db0aaf2 77d4dae2 13a3c9f1 64b0daf1 77d5afe2
12d6c9f0 14b0d8f1 77d5aae2 66a3c987 14b0ac81 77a6afe2
61d6c986 11b0ad84 77a6aae2 61d3c981 15b0af84 6db0aaf2
77d4dae2 13a3c9f1 64b0daf1 77d5afe2 12d6c9f0 13b0d8f0
77d5ade2 66a2c987 13b0ac86 77d5ace2 12d5c9f7 12b0dc87
77d5ade2 12d4c9f6 16b0de87 6db0aaf2 77d4dae2 13a3c9f1
64b0daf1 77d5afe2 12d6c9f1 64b0d981 77d6dae2 67d3c984
64b0aff1 77a7d9e2 60a0c981 67b0aaf2 77a7dae2 60a3c986
63b0acfa
Please save this file as it may hold crucial details
on what caused the crash, and that helps us to
fix the bugs and make better software. Thanks!"
I know it doesn't work when it does that, so I delete the file and start back from my last save point. |
Posted: Thu Aug 09, 2007 7:08 pm Post subject: |
Thanks for posting the stack dump! The fact that it wasn't giving any sort of error was unusual. You probably don't need to send me that OBJ now because I think I know what the problem is. Read this posting for a possible solution ...
http://www.headus.com/phpbb/viewtopic.php?t=202
Update: Just got your OBJ in email. Loads fine here, so it probably is the problem as described in the above posting. |
Anhslaught
Posted: Fri Aug 10, 2007 1:09 pm Post subject: |
headus wrote: | Thanks for posting the stack dump! The fact that it wasn't giving any sort of error was unusual. You probably don't need to send me that OBJ now because I think I know what the problem is. Read this posting for a possible solution ...
Hmm I don't understand the problem. Does it have something to do with my liscense? I applied for this license a few months ago and it still works so I never asked for a renewel. How would I remove everything? Delete them from the root file after uninstalling? And can you email me another license? Thanks in advance Phil.  |
