3d view is not showing anything at all
JNeuburger86
PostPosted: Thu May 10, 2007 10:57 am    Post subject: 3d view is not showing anything at all Reply with quote
when I go in to 3d mode there is absolutly nothign visable it is just grey. why would this be happening I tried the new versin from yesterday adn the april 17th version and the one before that they all are displaying this way on my machine.
i have a NVidia Geforce 79 Gs video card
with a 2.4 gig processor and 2 gig of ram if that helps you solve my problem i nany way
PostPosted: Thu May 10, 2007 5:27 pm    Post subject: Reply with quote
Is it every file you try and load that doesn't show, or just the one? Is there any chance you could email me one of your OBJ files so I can see what happens here?
eddgar
PostPosted: Mon Jun 18, 2007 10:15 am    Post subject: obj not showing in uvlayout Reply with quote
After searching, I've found a couple of questions like this, so I'm here..
I'm using uvlayout v1.19.3 FC7. I can see the torus (and the skull in ../data) but not my models. They are different in 'size'.
Also, when trying to load any geometry exported from maya (default polySphere, no transformation, just create/export), I get an error:
" Mesh topology too broken to load. 'Try Clean' in Load Options..." I found this when trying to see if the default geometry could be visible :/
I've already emailed you a couple of obj files to see if there's something there..
thanks in advance
edgar
PostPosted: Mon Jun 18, 2007 6:44 pm    Post subject: Reply with quote
Confirmed! The OBJ import for the 64bit builds is broken. Obviously I didn't test that properly. Will fix it today.
PostPosted: Mon Jun 18, 2007 8:05 pm    Post subject: Reply with quote
Fixed. You can now grab the new Fedora7 and Kubuntu7 64bit installs from the Linux download page ...
http://www.uvlayout.com/linux/
eddgar
PostPosted: Wed Jun 20, 2007 12:32 pm    Post subject: Reply with quote
Thanks!
Working great.. I still have to get used to the workflow, but everything is working great with v1.19.4
PostPosted: Wed Jun 20, 2007 5:56 pm    Post subject: Reply with quote
Excellent! Thanks for the update.
