JNeuburger86
Posted: Fri May 11, 2007 2:22 pm Post subject: Program has fatal crashevery few minutes |
All day today and yesterday i have been usin all different versions of this program on my computer and i keep having fatal crashes every few minutes. If there are logs I can send you jsut let me know where to find them. It is making working impossible. also when I reopen the last saved file everything is slightly red everywhere so all the tweaking I di on the UVs is lost and I have to reflattten every piece |
Posted: Fri May 11, 2007 7:19 pm Post subject: |
Are you getting an error message at all, or does it just die?
JNeuburger86
Posted: Mon May 14, 2007 6:33 am Post subject: It does give an error |
It says that it has crashed from a fatal error. Some times it even allows me to send an error report with windows. |
JNeuburger86
Posted: Mon May 14, 2007 10:46 am Post subject: |
I have a theory that this may have something to do with my video card becuase it seems to happen between switching between the 3 views. The really concerning thing is that that even when I save before it crashes and I reopen the file everything acts as if I had scaled it because it all the flattened bits turn slightly red. When I take this same OBJ in to the purchased version of cyslice that mcirosoft has which as I told you before is a different version of your software (version 1.6) it seems to work fine in there but what I am now thinking is it is not the version but the difference in the two systems some where becaue I went to the last version of the trial software that I could download off of your site and it still has these same problems of crashing and of loading my UVs up differntly than they looked when I saved them.
My specs on this computer
Video Card: NVIDIA GeForce 79 GS and I have a dual monitor setup
Intel (R) Core (TM)2 CPU
660 @ 2.40 GHZ
2.39 GHz, 2.00 GB of RAM
I will have to get the other one to you later but htat is the ine that is crashing |
Posted: Mon May 14, 2007 4:51 pm Post subject: |
Could be UVLayout not playing nicely with nVidia dualview. Other people have reported problems with that before, but they did seem to go away, so I stopped worrying about it. Try turning that off to see if it makes any difference.
Are you running XP? I just had someone report similar problems with a Vista install.
JNeuburger86
Posted: Tue May 15, 2007 10:25 am Post subject: That does seem to be it with the crashing |
I finally think I figued out what was making it crash. the first thing I do every time I start is move the menu bar to the other monitor. today i am working on it with the menu and the view port in the same monitor and it took an hour to crash not perfect, but that is pretty darn good because before it was minutes. The same thing was happening when I did it with the other computer too so that is surely part of it.
So now there is just the last problem which is the scaling thing when I open a saved file in the two pictures I attached with this post you can see that though it is not perfect the UV are layed out pretty well on the JPG called "before_save.jpg"
but when I save that file and reopen it the UV view looks like the JPG named "aftersave.jpg"
Note that when it is saved the whole thing isn't in the UV mode viewport some of it is still in edit and when I reopen it is all is in the UV viewport. and when I save it auto fit is on and when I reopen it, it is set to off. So the unuvd part appears in the bottom corner of the screen as you can see i nthe JPgg named aftersave-first.JPG that is also in with this post. Do you know what is causeing that becase with this crashing it is making tweaking my UVs and saving them not useful cause when it comes back they are all screwed up anyway. |
JNeuburger86
Posted: Tue May 15, 2007 10:54 am Post subject: A Little more info for you on the crash |
ifigured out why it crashed afteran hour it was because I got an E-mail, and I had outlook in the other window so when out look refreshed my other monitor it made the program crash making it even further proven that it has somethign to do with the dual monitors Just thought i would let you know. I hope this is somethign you can figure out because I was hoping to buy a copy of this program for myself but there isn't a computer i have that isn't set up with dual monitors and all of them also have NVIDIA cards so hopefully you can find where it is failing
Jenny |
Posted: Tue May 15, 2007 6:33 pm Post subject: Re: A Little more info for you on the crash |
"... so when out look refreshed my other monitor it made the program crash making it even further proven that it has something to do with the dual monitors "
Yes, it sure does look that way. OK, I'll bump this one up the "to do" list, and hope to have a look at it sometime in the coming week.
Regarding the scaling, try turning "Set All UVs on Save" off in the preferences.
JNeuburger86
Posted: Wed May 16, 2007 9:33 am Post subject: Thanks Phil you rock |
thanks for all your help the last couple of days I really appreciate it
Jenny |
izmozer
Posted: Thu Jun 21, 2007 12:41 pm Post subject: |
hello i try the last beta at home and at work
and i have all the time a crash when i change between mapping view and 3d view.
at work and at home, and i have a dual screen system.
edit :
i'm not sure is a dual screen problem for me, but it crash on 2 computer different.
all the time i want go in uv view, - it's crash
uvlayout v1.19.3 2007/06/13 15:16:40
9971fd50 a351be60 b935ce70 db44dd65 ac51c465 b945c470
ad48dd68 a051bf66 b945c470 db47dd64 a051ca16 b946be70
ae32dd13 da51cb12 b935c570 dd34dd67 a051cf68 a351be60
b935ce70 db44dd65 ac51c465 b945c470 ad48dd68 a051bf66
b945c470 db47dd64 a051ca16 b942be70 aa32dd68 da51cf12
b948c570 a034dd63 a051cb68 a351be60 b935ce70 db44dd65
ac51c465 b945c470 ad48dd68 d851bf65 b945bc70 db44dd64
d851ca13 b942bb70 aa37dd68 df51cf68 b948bf70 a035dd63
d851cb16 a351be60 b935ce70 db44dd65 ac51c465 b945c470
ad48dd68 d851bf65 b945bc70 db44dd64 d851ca13 b937bb70
df37dd64 df51b868 b944bf70 ac35dd16 d851bc16 a351be60
b935ce70 db44dd65 ac51c465 b945c470 ad48dd68 db51bf64
b945bf70 db45dd64 db51ca14 b946b870 ae34dd13 dc51cb69
b935bc70 dd32dd67 db51cf15 a351be60 b935ce70 db44dd65
ac51c465 b945c470 ad48dd69 ac51bc11 b944c870 d830dd65
ac51cb63 b934cd70 dc41dd65 a951bb67 b945c970 ad43dd15
ac51cf13
Please save this file as it may hold crucial details
on what caused the crash, and that helps us to
fix the bugs and make better software. Thanks! |
