moochie
Posted: Mon May 07, 2007 2:16 pm Post subject: Small Video Tutorial |
Someone on another forum (Renderosity) was having difficulty mapping a cube in another uv program, because the cube was rotated at an odd angle. I created this short vid to show how Layout makes short work of not one, but two twisted and over-lapping cubes. Unfortunately, I keep referring to the cubes as 'spheres', but that's because (a) I'm dim and (b) I've been using ZBrush a lot recently, and I have ZSpheres on the brain!
http://www.pantsofpower.com/boxes.avi 16mb avi, TechSmith codec. RC > save as or LC and wait. |
Posted: Mon May 07, 2007 9:37 pm Post subject: |
Thanks for sharing the video, and putting a voice to the login name! I must say I found it very interesting to see someone else using UVLayout. Here's my own attempt at flattening a cube (1.5Mb Quicktime), using some short cuts you might find useful ...
http://www.headus.com.au/doc/uvlayout/videos/UVLayout-Speed-Cube.mov
- Used G painting to detach that first face ... sometimes quicker than C edge tagging. On bigger meshes you can also aim the mouse pointer at clear space, then hit G to bring up the marking menu, then F to select all polys facing forward. Doesn't work on that small cube though.
- C tagged the other split edges without changing the view; you can pick edges from the inside of a mesh if you want.
- You don't need to point at the red weld edge when M hotkey snapping shells together; just pointing somewhere in the shell is enough. You can also use Shift-M to snap the other shell to the picked one. This saves you from having to zoom out and find the other shell that you want to weld to the one you're working on.
- Used Ctrl-Up-Arrow on an edge in the final flattened shell to align it vertically.
moochie
Posted: Mon May 07, 2007 11:38 pm Post subject: |
| Ah yes .. much more elegant. Ctrl+ Up arrow is a new one on me .. that's a keeper! |
Rich-Art
Posted: Tue May 08, 2007 12:25 am Post subject: |
Very Nice little tutorial Moochie.
I see you use C4D as well. Great to see there are more C4D users that use UV-Layout.
You have a nice voice to listen at.
Peace,
Rich_Art.  |
Lewi
Posted: Wed May 09, 2007 4:46 am Post subject: |
Nice videos guys .Moochie you know if you look in your UV Layout Folder in Program Files there is the Keyboard and Mouse viewer application that Phil uses in his vids. I think you can use it for tutorial videos if you own UVLayout. Is that right Phil ?
One small thing about it though, I haven't sussed a way to close it with out going through the task manager. lol. Its a fantastic little app for teaching hotkeys and workflow though showing all three mouse presses and key combos with modifiers. |
moochie
Posted: Wed May 09, 2007 12:38 pm Post subject: |
Lewi .. thanks! That's brilliant! Esc seems to close the app ok. What a great find .. I assumed the mouse/keystrokes viewer was part of the screen capture program.
In case this is an unsupported feature, or one Phil didn't intend making public, I won't name the element that makes this work. But it's uber-cool!
Later: omg, Phil .. that little utility is a work of genius. Please, can you tell me what I'm allowed to use it for, in terms of creating screen-capture tutorials? I do ZBrush tuts, and this would be such a benefit appearing on screen. Is its use included in my dongle licence? Cheers! |
Lewi
Posted: Wed May 09, 2007 12:57 pm Post subject: |
| Esc , thought I'd tried that lol. I stumbled across it by accident but there is a post on the forum somewhere mentioning its usage and terms. I think a forum member requested info on the app and its availability after seeing it in the tut vids, and it turned out Phil had made it specifically for the videos. It then became part of the beta download from then on but its not documented as far as I have seen. I just clicked it out of curiosity one day and what a great suprise. |
moochie
Posted: Wed May 09, 2007 1:39 pm Post subject: |
Oh yeah .. v1.11 .. Phil wrote "- includes the "kbstate" application used when recording the videos
(see keyboard/mouse feedback at top of screen) . This isn't
required for the normal functioning of UVLayout, but someone wanted
to use it for their own videos, so here it is! Note: kbstate will
only run if you have a current UVLayout license."
So really the only unanswered question is .. can I use it in non-commercial video tuts for other software too? No worries if not .. would be darned handy, though. You can count on a handsome credit and exposure to a new market.  |
Posted: Wed May 09, 2007 5:55 pm Post subject: |
Use of the kbstate program is under the same restrictions as UVLayout itself; if you've purchased a license, you can use it however you want! The current beta users can do that too. The only future restriction will be on Student licenses, which are non-commercial only.
Oh, and yes, ESC is the only way to kill it. And there's some command line args you might want to play with ... open up a command shell and run "kbstate -h" to see what those are. Note: default decay time is "500".
moochie
Posted: Thu May 10, 2007 12:00 am Post subject: |
Wonderful .. thanks! You should have a chat with TechSmith .. maybe you could licence the idea behind kbstate to them for inclusion in Camtasia? I don't know anything about the technical issues, but the concept is a perfect fit. (cough*10%*cough).  |
Posted: Thu May 10, 2007 1:25 am Post subject: |
Looks like they're probably already working on something for an upcoming release ...
http://forums.techsmith.com/showthread.php?t=3319
Actually, I was surprised they didn't have something already to do it.
moochie
Posted: Thu May 10, 2007 9:39 am Post subject: |
| Well, that thread was over a year old. Can't hurt to make contact with them. Kerrr-ching! |
Posted: Fri May 11, 2007 1:54 am Post subject: |
Hmmm, yes, I might just do that!
Ganapoes
Posted: Sat Dec 03, 2011 12:30 am Post subject: |
