1.17.1 Something is wrong with Export from UVLayout
bolba
PostPosted: Wed Mar 28, 2007 10:19 am    Post subject: 1.17.1 Something is wrong with Export from UVLayout Reply with quote
Hello.
I'm trying to save unwrapped .obj file from UVLayout 1.17.1 but when I import file in 3ds max - I got no UV's. It worked for sure in previous versions. Something has changed?
Maybe something is wrong with my model, but anyway, UVLayout fails on export to .obj not on unwrapping.
Thanks.
PostPosted: Wed Mar 28, 2007 6:32 pm    Post subject: Reply with quote
Thanks for the UVL file ... there's a dozen or so unflattened polys in there, so maybe the partial UVs (ie not all polys have UVs) in the exported OBJ is causing problems in the 3ds importer? Under UVLayout Preferences, try ticking the "No Unset UVs on Save" option. If that doesn't help, send me the OBJ and I'll take a look at that.
bolba
PostPosted: Wed Mar 28, 2007 8:37 pm    Post subject: Reply with quote
Yes, something has broken in .obj file between export from 3ds max and import to UVLayout. Mesh is pretty normal in 3ds max Smile
I have used Save Morph Targets to OBJs to get UV's from UVLayout.
I will try your advice next time if I'll have similar problem.
Thanks.
PostPosted: Wed Mar 28, 2007 9:25 pm    Post subject: Reply with quote
Ahhh, OK, "Save Morph Targets" only saves out flattened polys, so I'm pretty confident its the partial UVs thing I already mentioned. I'll make that preference setting the default, because this seems to be catching a lot of people out.
