UV mode - laying out your pieces for the map
Atlantis
PostPosted: Sun Jan 07, 2007 2:14 pm    Post subject: UV mode - laying out your pieces for the map Reply with quote
When you drop the pieces into UV view, it spreads them out in a straight line which can get long if you have a lot of pieces.
Is there any way to grab or make a window box around several of these pieces and move them into the red square work area to position them?
PostPosted: Sun Jan 07, 2007 6:12 pm    Post subject: Reply with quote
If your multiple pieces have the same number of edges on their boundaries, you can use the gather/stack tool to move a bunch of then together (ie move one, and gather the rest).
But other than that, yes, you have to move them one at a time. Someone else recently requested some sort of "group move" function, so hopefully that'll get done soon.
