Unknown fatal error
melamkish
PostPosted: Mon Dec 25, 2006 6:32 pm    Post subject: Unknown fatal error Reply with quote
Just started trying to use UVLayout, most current beta.
After loading an obj file, and doing nothing other than spin the model around in 3D view, I get an Unknown Fatal Error Detected. Exiting. message. UVLayout graphic window closes and a send an error report to Microsoft pops up. Every time.
I have tried several different obj's with the same result each time. I have tried it both with mapped and unmapped files. Same results. I am pretty sure the obj's don't have problems because they can be imported into different programs with no issues.
Any suggestions on where to start troubleshooting? I am using a dual core motherboard and high end system with lots of ram. I can post any specification that may help.
I am impressed by what UVLayout can do (from watching the videos) and would really like to solve this problem.
edit - I may have been premature in posting. There was a graphics driver update for my nvida card just a few days ago. Updating the drivers may have solved the problem.
PostPosted: Tue Dec 26, 2006 5:17 pm    Post subject: Reply with quote
Thanks for the update on the possible driver install fix. I have my fingers crossed here :-)
melamkish
PostPosted: Tue Dec 26, 2006 5:55 pm    Post subject: Reply with quote
I did get one error since updating the drivers, but I may be able to attribute that to a procedural error on my part.
I suspect the original issue before the driver update was an Open GL issue. It would occasionally crash one or two other graphics intensive programs.
I have my fingers crossed also, hoping my other problems are solved.
As for UV Layout, it has performed flawlessly so far and I am impressed!!!
