phongsta
Posted: Sat Jan 23, 2010 12:25 pm Post subject: Linux Path Error. |
I am testing uvlayout trial on a ubuntu linux system. I have configured the path correctly for HEADUS_HOME, PATH and LD_LIBRARY_PATH. uvlayout starts up just fine but when I try to view the user guide from the menu I get an error in the shell
---bash output---
if: Badly formed number.
is there a way to correctly configure uvlayout to see all of its files? I noticed this same shell output from headus 3d tools also. I installed to a /home/user/ dir. I use uvlayout at work and do not get these errors.
thanks. |
Posted: Sun Jan 24, 2010 5:18 pm Post subject: |
The user guide is just a PDF file, which you can find in the "www" subdirectory on the UVLayout install directory, so find that and view it as you normally would a PDF file.
The software runs a shell script called "browser" to view the file, and I suspect that's where the error is coming from. If you type "uname" into a shell window, what output do you get?
phongsta
Posted: Sun Jan 24, 2010 9:03 pm Post subject: |
I am running CrunchBang Linux 9.04. its a repackage of Ubuntu 9.04 with fluxbox window manager.
uname -a out is as fallows...
Linux foo-laptop 2.6.28-13-generic #45-Ubuntu SMP Tue Jun 30 22:12:12 UTC 2009 x86_64 GNU/Linux
yes it looks like bash in unable to read your csh scripts.. here is a quick conversion of your csh to bash. this should work for all programs in the path, this works for txtedit also. evince is my pdf reader btw.
-----bash browser script-----
#!/bin/bash
if [ `uname` == Darwin ]; then
exec open "$1"
else if which evince >/dev/null; then
exec evince "$1"
else
exec xmessage -nearmouse " No browser found. See ...\
$0 "
fi
fi
fi
done
one more quick question if you don't mind me asking...
Can I purchase a single Professional License without a physical dongle? I really don't what to use such a thing. A license key or single floating licence would be preferable. |
Posted: Sun Jan 24, 2010 11:27 pm Post subject: |
"it looks like bash in unable to read your csh scripts.. "
Yes, correct, but I thought that '/bin/csh' was installed on all linux systems? If its not there, then installing "tcsh" should fix it.
"Can I purchase a single Professional License without a physical dongle? "
Yes, you can have an Ether license if you want. The differences are explained on "uvlayout.com/keys". Just let me know after making the order that you don't want a dongle.
phongsta
Posted: Mon Jan 25, 2010 12:31 am Post subject: |
great,
thank you for the info. |
