Posted: Mon Jul 10, 2017 1:03 am Post subject: UVLayout v2.10.01 now available |
Hello All,
UVLayout v2.10.01 is now available for all users from ...
New tools added to Professional version:
- Layers : Organize shells into different layers. Shells in the
upper layers will appear over shells in the lower layers where
they overlap. Shells not in the active layer are tinted gray and
behave as if they are locked.
Pro tools now in Hobbyist/Student version:
- Pack : Boxes, used to keep groups of shells together when
packing.
- Pack : Tick Rotate and shells will be rotated by the 90 degree
increments to see if that gives better packing.
Changes to existing tools:
- Copy UVS : When the Stack option is selected, matching shells
are now automatically boxed as well as locked.
- Pack : Map resolution and pixel bleed settings are now saved
into and restored from UVL files.
- OBJ Export : By default, all vertex information is written
into exported OBJs at the start of the file. If you tick the
"OBJ Export Grouped V" preference, then the vertexes are grouped
in with the faces. Resolves a problem with vertex grouping in Maya.
- EPS Export : Optional Color option; the boundary remains black,
but valley folds will be blue and ridges red.
- DXF/EPS Export : X and Y scale factor added if you want to
tweak the exported coordinates.
- Render : Option to crop the rendered images to the visible
polygons in each tile. Alternatively, if you set the crop border
to a value of "a", then the tile is cropped to a portrait A sized
paper aspect ratio.
Bugs fixed:
- Pack : Auto Fit is now turned off automatically whenever the
pack tool is used.
Installation changes:
- Windows : Each new version can now be installed alongside
older ones.
- Linux : Launch scripts are now bundled in with the installer.
- Floating licenses : Communications with the license server are
now more tolerant of drop-outs, meaning UVLayout will continue
to run uninterrupted if the server hardware or software crashes
and restarts. Also requires that HLServer be updated to v2.04 and
Supervisor mode is turned on.
