"Nothing in UV, see Ed"
samhodge
PostPosted: Thu Sep 11, 2014 11:04 pm    Post subject: "Nothing in UV, see Ed" Reply with quote
When loading up a model here at work a number of artists are having problems when an OBJ with perfectly valid texture coordinates, will not display the UVs in uvlayout from the command line.
Any hints?
When UV layout is working its awesome by the way, we cant work out what has broken it. It works for one or two users but others are having no luck
Sam
PostPosted: Fri Sep 12, 2014 4:51 pm    Post subject: Reply with quote
Resolved via email ... user needed to select "Edit" in the Load Options window when importing the OBJ into UVLayout.
