serum
Posted: Tue Jan 08, 2008 5:25 pm Post subject: Vista problem |
| Hi, I am running Vista...I double-clicked the exe file after downloading, and see the command prompt window open briefly, but nothing else. Does it not work under Vista? |
Posted: Wed Jan 09, 2008 12:24 am Post subject: |
Double clicking the downloaded EXE should run the installer. Once UVLayout is installed, you should use the desktop icon to get it running ... drag'n'drop an OBJ onto the icon to load that file into UVLayout.
Yes, UVLayout should run under Vista ... I've tested it here on both 32bit and 64bit systems.
serum
Posted: Wed Jan 09, 2008 3:42 am Post subject: |
| Thanks, Phil. I downloaded the file a second time, and it works fine. |
