tedg
Posted: Sun Dec 19, 2010 3:07 pm Post subject: obj not loading |
I'm on a Mac, and so far, after loading Headus, I can only launch the Torus test- when I try "Load", an .obj I saved on my desktop does not appear in any of the directories. I followed the directions given for another individual having similar problems- I entered "Desktop" within the Temp Dir inside of Common Preferences, and restarted, but the .obj on my desktop does not appear in any directories. I also tried dragging and dropping the .obj onto the Headus Icon within my application folder, which launches Headus, and the .obj appears inside of "UV Layout Load", under the Filter column. But when I click "Load' the Error message: "Problems loading No such file or directory" appears. I didn't have these problems with an older version- I'm using the most current Headus version on OS 10.6.5
What am I doing wrong? |
Posted: Sun Dec 19, 2010 6:25 pm Post subject: |
Not sure, but try putting the OBJ into a folder via the Finder and then you know for sure where it is.
Also double check the name of the file; its possible there's a space at the end, so is might appear as ".obj" but really be ".obj<space>", and that's why you're having problems loading it.
