BAR-CODE
Posted: Fri Oct 29, 2010 5:35 am Post subject: PRO version Export mistake or ... ? |
I have this tool for more then a year now but never had the time to actualy use and learn it.
So i started this week and it looks nice.
But now i have loaded a OBJ file with color zone and group zones.
When i have flattend the obj and Save is as a OBJ...
Every thing i sgone ..the color mat zones the grouping zones..
All that left is a Headusobj. file ..what am i doing wrong..
I have the PRO version but i dont htink it save's as the PRO version.. do i mis something??
Chris |
Posted: Fri Oct 29, 2010 5:13 pm Post subject: |
To preserve groups in the OBJ file, you need to use the "Update" button. Select the original OBJ file that you loaded into UVLayout, and a copy is made with all of the original grouping info and the new UVs.
BAR-CODE
Posted: Sat Oct 30, 2010 3:08 am Post subject: |
| headus wrote: | To preserve groups in the OBJ file, you need to use the "Update" button. Select the original OBJ file that you loaded into UVLayout, and a copy is made with all of the original grouping info and the new UVs.
i hope you count material zones as grouping too ?
EDIT it does incl mat zone..but it only did so when i selected them before updating the OBJ...
But while im here ... how can i rotate a part on a other axe in the uv section?
Maybe im not looking for the right word but i cant find it in the Pdf ...
Thnx !
Chris |
Posted: Sat Oct 30, 2010 5:29 pm Post subject: |
If you use "Update", everything that was in the original OBJ file will be in the new one. You have to be careful though because OBJ files cant always save all of an object properties, so you might still lose something through the export and import process. It really depends on which modeler and OBJ import/export method in that application that you're using.
I recommend checking out the UVLayout transfer plugins, because some of those will replace the UVs of the object loaded in the modeler, preserving all other properties ...
http://www.headus.com/phpbb/viewforum.php?f=13
"how can i rotate a part on a other axe in the uv section"
Once a piece of geometry is in UV space, you can rotate it with Space-LMB (Hold down Space and click'n'drag the Left Mouse Button). If you need to flip it over, use the key pad arrow keys.
BAR-CODE
Posted: Sun Oct 31, 2010 3:35 am Post subject: |
thank you . i picked up the MODO plugin too :}
Chris |
dorkati
Posted: Mon Sep 24, 2012 10:47 am Post subject: |
Sometimes I still got same problem. I checked inside UVLayout and there are group and material informations (all listed in groups and materials section) and even if I clicked on update button, when I open my obj in Hexagon, I got an "HeadusOBJexport" group and lost all materials.
It didn't happen with me since a year and today I got same result again and again.
I have Pro version. |
Posted: Mon Sep 24, 2012 6:24 pm Post subject: |
"I have Pro version."
Which version number?
