Resolved - Old bug resurfacing?
Aliastasia
PostPosted: Tue Oct 05, 2010 10:37 am    Post subject: Resolved - Old bug resurfacing? Reply with quote
Issue between Keyboard and Chair. What you THINK is UV space, may NOT be UV space...
I'm not sure whether it's an error between keyboard and chair, or a 2006 bug resurfacing:
Map your mesh.
Be happy with map.
Use pack-function, move shells around a bit
Press Update to save mesh
Hit Render
Increase layout file to 1 k
Use AA, Outline On
Press Save (working directory has been defined)
All I get is a white page with a faint smudge on top.
Everything is inside UV space
The UVs get updated, though, I checked in UU3D and Max
Ironically, it's an issue just as I am finishing up a three-stepper on how to map a horse in UVL.
Am I forgetting something, or is this an issue?
Thanks Smile
/A
PostPosted: Tue Oct 05, 2010 6:49 pm    Post subject: Reply with quote
Definitely sounds like a bug. Try reloading the edited mesh and render out the map and see if you get everything then.
