AnatolM
Posted: Wed Sep 01, 2010 9:57 pm Post subject: Copy UVs in same mesh |
hello, why copy UVs doesn't work well in same mesh often? For example: I've got very simple low poly object (in attach) and I want left and right sides has the same UV's, but after copy UV's it looks like in screenshot - doesn't right (first - I marked one side, detach it, mark another side and detach, after segment one side or drop and flatten - doesnt matter, after that i try copy Uv's in 3d view or drop another side and copy - doesnt work well). |
Posted: Thu Sep 02, 2010 2:58 am Post subject: |
Which version of UVLayout are you using? The Copy UVs tool is working OK for me with that mesh, as long as the second side is detached before copying.
AnatolM
Posted: Thu Sep 02, 2010 4:28 am Post subject: |
Hmm, works well, but if u choose vertical edges only and only with outside, but doesnt work with any horizontal edges and inside vertical |
