opening existing UV layout
sketchbookinc
PostPosted: Mon Aug 16, 2010 9:35 pm    Post subject: opening existing UV layout Reply with quote
I flattened a bunch of UVs on an object - sent off, and the model came back to me slightly tweaked. no new UV's but the mesh has been deformed slightly.
i can't seem to find a way to re-open the OBJ so that i can see the UV's.
Anyone know how to do this?
PostPosted: Mon Aug 16, 2010 10:02 pm    Post subject: Reply with quote
When you load the OBJ into UVLayout there's an Options window where you can select either "Edit" or "New". The first one there, Edit, will load existing UVs if any are in the file.
sketchbookinc
PostPosted: Tue Aug 17, 2010 9:07 am    Post subject: Reply with quote
thanks Phil!
