Normal Lock I/O
pokopoko_aquila
PostPosted: Thu Jun 03, 2010 10:57 pm    Post subject: Normal Lock I/O Reply with quote
hello, all
i trainning trial version. once ,i have one question/requests.
my workflow is that " CAD > Maya > UVLayout > Maya ".
this flow has one problem that "Normal Lock" had changed "Normal Unlock" in UVLayout.
(all smooth edge changes to hard edge)
if you can, please tell me how to way keep " Normal Lock".
i excuse , UV Unwrap tool "Roadkil" can keep "Normal Lock" to "Normal Lock".
reference
ttp://www.pullin-shapes.co.uk/page8.htm
im sorry my little English..
thank you
PostPosted: Thu Jun 03, 2010 11:06 pm    Post subject: Reply with quote
When exporting your mesh from UVLayout, use the "Update" button instead of the "Save" button. You then select the original OBJ file that was loaded into UVLayout and a copy is made with only the UVs changed. This preserves all the other information in the OBJ file such as the surface normals.
pokopoko_aquila
PostPosted: Fri Jun 04, 2010 12:37 am    Post subject: Reply with quote
thank u for very fast reply!!
my work got good result !
thank you!
