hayhamLT
Posted: Wed May 05, 2010 2:39 am Post subject: 3DSMax interface script modified |
3DSMax to uvlayout script v3
UV Pipe by Robert Fletcher
Mod by zM TeaM
This is untested, free, beta software. use/edit at your own risk.
Installation
*Drag and Drop the "uvpipe_3_mod_by_hamLT.mzp" file onto your max viewport.
*Restart Max or browse to the scripts folder "C:\Program Files\Autodesk\3ds Max Design 2011\Scripts\uvpipe" and manually run the script "uvPipe_3.ms"
*Go to Customize -> Customize User Interface
*Click the toolbars Tab
*Change the Category to "_UV Layout Tools (by hamLT)"
*Drag the "headus UV layout bridge" action onto your UI or add it to a new toolbar
*Close Customize UI
*Press the new Button
*A box will come up asking for your "UVlayout.exe".
CHANGE LOG:
11th May 2010
*UVChannel Choicer
*Error Checker
I made some modifications to this Plug-in, maximum adjusting to my work nature.
| Description: |
| Filesize: |
44.36 KB |
| Viewed: |
236589 Time(s) |
| Description: |
 Download |
| Filename: |
uvpipe_3_mod_by_hamLT.zip |
| Filesize: |
6.05 KB |
| Downloaded: |
16373 Time(s) |
Posted: Wed May 05, 2010 6:56 pm Post subject: |
I split this out of the original 3DSMax script posting so it was easier for people to find.
r_knightly
Posted: Mon May 10, 2010 11:44 am Post subject: |
please reinstate my Credit and change log and add yourself to it, I've no problems with you using my code and branching but removing my credit looks disrespectful and dishonest.
Im pretty sure your trying to be helpful,l but adding a uv checker and a channel selector isnt grounds for removing my credit comments from my script or crediting yourself totally in the UI
Thanks
Posted: Mon May 10, 2010 8:01 pm Post subject: |
I second that!
hayhamLT
Posted: Mon May 10, 2010 11:19 pm Post subject: |
I change the log & UI, see first post. Sorry for negligence.
Thnx
r_knightly
Posted: Tue May 11, 2010 1:26 am Post subject: |
thank you
I was looking at your code and I noticed you use a bitmap for the checker pattern. are you aware that max can create this for you with one of its built in procedural textures.
eg.
| Code: |
nNode.material.diffuseMap = Checker()
No need to distribute an extra bitmap
TexeL
Posted: Thu May 13, 2010 11:59 am Post subject: |
| Quote: |
$.material= standard diffuseMap:(checker()) showInViewport:true
using checker();
using bitmap for btn;
r_knightly
Posted: Fri May 14, 2010 2:31 pm Post subject: |
stomps
Posted: Thu May 27, 2010 3:40 pm Post subject: New UVpipe scropt Unknown System Exception |
I just noticed the new script and was excited to try it out. unfortunately I can't get it to run. Can you help me out?
I am getting this error. Unknown System Exception
I am one version behind the latest UVlayout update. Could that be a problem?
| Description: |
 Download |
| Filename: |
uvpipe3.txt |
| Filesize: |
10.42 KB |
| Downloaded: |
8505 Time(s) |
stomps
Posted: Thu May 27, 2010 3:44 pm Post subject: |
Ha! seconds after sending the reply I fixed my problem. It seems I need to apply uvs to all three channels before running the plug-in.
basically I applied an unwrap uv modifier to channel 3, collapsed the stack and ran the script.
TexeL
Posted: Fri May 28, 2010 11:36 am Post subject: |
Script Should Add Automatically 3-rd Channel
| Code: | | polyop.setMapSupport nNode mapChan true |
| Quote: | | I am getting this error. Unknown System Exception |
Please Give More Detailed Description For That Error !?!
r_knightly
nlsinh
Posted: Tue Mar 13, 2012 5:34 pm Post subject: |
| Thank you!
crux
Posted: Thu May 10, 2012 9:27 pm Post subject: |
| i'm getting flipped uvw faces after using this version, which i can't seem to fix. i don't have the same issue with the original uvpipe beta 2
fxzt
Posted: Sat May 12, 2012 8:15 pm Post subject: |
| Thank you!
