Posted: Thu Feb 25, 2010 2:31 pm Post subject: FIND IT! |
For a long time now I've wanted there to be a way to focus on what your working on
Imagine you are in the UV world, you highlight/tag a shell or shells then when you go to the 3D view if has some kind of display that shows you where it is.
A crazy arrow or ghosting effect perhaps................................scary
On simple models I just mark it (G). |
Posted: Thu Feb 25, 2010 5:59 pm Post subject: |
If you G mark polys in the UV view, you can focus in on those back in the 3D view with G-Home. If they're on opposite ends of the mesh it not much use though, but you could then try H-G and H-S to hide everything except those polys, making it easier to spot where they are.
"ghosting effect"
Actually that might work ... I could tweak the existing X-Ray viewing mode so that marked polys stay solid. The you'd be able to see them in context in the rest of the mesh.
Posted: Thu Feb 25, 2010 7:08 pm Post subject: yep |
Isolating it helpful but yeah seeing it in context of the model is generally the way I want to see it.
I was going to say you could add it to the G menu, but it's pretty chocka.
M |
