paqwak
Posted: Thu Mar 04, 2010 4:01 pm Post subject: LWO format |
Any chance to extend uvlayout with any other file fomat, like this good old .lwo for example.
I'm facing to some walls in my workflow actually.
My main software are MoI, Modo and uvlayout. And I have huge trouble to find a solution to unwarp models from MoI (moment of inspiration) and render/paint them in Modo.
MoI produce super sexy n-gones models from nurbs surface ... but .lwo is the only way to import them in Modo because Modo can't recreate ngones correctly from .obj format.
I can't use Modo to unwarp uv's because any geometry modification kill the vertex normal info, and ruin the shading. (As Uvlayout can only update uv's info, it's perfect)
... so there are few solutions :
- Waiting to have a good .obj import in modo
- Waiting for an update of the modo uv workflow (so vertex normals arent affected by any uv's job)
- Waiting uvlayout to have a option to import/save .lwo
As an extra note, the one uv channel limitation from .obj format is also a little bit annoying in 2010
I know I'm not using comm softwares here, but maybe it will help some other peoples looking for the same workflow.
Thanks for you time. |
JamesH
Posted: Fri Mar 05, 2010 1:53 am Post subject: |
| Have you tried the Modo UVLayout Plugin ? That way you can import the model from MOI to Modo using .lwo and then use the plugin to unwrap the UVs in Modo. |
paqwak
Posted: Fri Mar 05, 2010 7:08 am Post subject: |
Wonderfull, the modo plugin works perfectly and keep my vertex normal info safe, that's so great.
Thanks a lot. |
joetraff
Posted: Tue Jul 06, 2010 7:13 am Post subject: |
The plugin is cool.
It works fine with newer versions too.
debt solutions |
