Floating License
Sashmo
PostPosted: Thu Feb 25, 2010 5:53 am    Post subject: Floating License Reply with quote
we have a problem with our floating license.
We got the hlserver running and everything is working properly in the IP-Range 10.0.0.*.
Now we have another IP-Range (192.168.10.*) from which it should be allowed to connect to the LicenseServer.
I tried to change the Group Lan entry in the Server Configfile like this:
GROUP Lan 10.0.0.*, 192.168.10.*
but had no luck. The Log sais access denied for 192.168.10.*. What changes do i have to make so that i can access the server from more than one IP-Range?I have restarted the server and I tried ";" as seperator, too.
would be great if someone can help us!
Thanks!!!
Sascha
PostPosted: Thu Feb 25, 2010 5:45 pm    Post subject: Reply with quote
Comma should definitely be working.
In your example above I can see a space after the comma. I bet that's the problems there .... actually, I just tested it here and that does break it. Remove the space and hopefully that'll fix it.
