robn
Posted: Thu Sep 10, 2009 6:03 am Post subject: how to get a larger rendered image? |
Is it possible to get a larger rendered image out of uv lay-out. When you have several forms in one image they become each very small..
Rob |
Posted: Thu Sep 10, 2009 5:17 pm Post subject: |
Are you clicking on the arrow to the right of "256" in the Render panel? It'll go up to 4k, which is 4096 pixels square for the output map.
robn
Posted: Thu Sep 10, 2009 5:49 pm Post subject: |
thank you, that is musch better. Only I don't see edges in the rendered figure .I see just some pixels. I cheked "AA lines" and "fill poly's" |
Posted: Thu Sep 10, 2009 6:01 pm Post subject: |
The image viewer that runs after the Render will show the whole map by default, so if you've selected "4k" then edges could be disappearing because the image is zoomed down so you can see it all. Use the "1" hotkey key in the image viewer to zoom in, or re-render at 1k maybe.
robn
Posted: Fri Sep 11, 2009 6:22 pm Post subject: |
Thanks, I discovered that 512 is the best option . It gives quiet a large picture and you can see the edges . |
