move objects in red square
robn
PostPosted: Wed Sep 02, 2009 12:47 pm    Post subject: move objects in red square Reply with quote
started to work on another file with one singel object. Split this object in two in edit moment and then transported both to uv mode.
In uv mode a red box appears and one object does not fit in that box. How can I move the object in the red box so it fits between the lines. It is frozen now and I cannot use
the flatten tool.
thanks.
Rob
PostPosted: Wed Sep 02, 2009 5:56 pm    Post subject: Reply with quote
Turning on "Auto Fit" will fit the 0-to-1 UV space "red square" around all the flattened shells. The frozen thing sounds a bit worrying though ... you should be able to flatten shells regardless of whether they're inside or outside the red square.
robn
PostPosted: Thu Sep 03, 2009 6:42 am    Post subject: Reply with quote
thanks . I can move my objects now and the flatten tools also works.
