Modo 401 Plugin - 1.2
Goto page 1, 2  Next
JamesH
PostPosted: Sun Jul 19, 2009 9:27 am    Post subject: Modo 401 Plugin - 1.2 Reply with quote
This is a python script that allows UVLayout to be used as a plugin for Modo 401.
Attached to this post is a zip file, extract the archive and copy uvlayout.py and uvlayout.lxm files into your scripts folder, for Windows 7 it is
Code:
C:\Users\<Your username>\AppData\Roaming\Luxology\Scripts
And I think for XP it is
Code:
C:\Documents and Settings\<Your username>\Application Data\Luxology\Scripts
Then copy the uvlayout.cfg into your Configs folder, it is located in the same folder as the above Scripts folder.
At the start of the script (uvlayout.py) is a file location for where your uvlayout.exe is located, there are some for XP and WIn 7 that have been added and commented out. You will need to uncomment one of these or add your own to suit your own system. The UVLayout intermediary files have been moved to the Temp folder identified using Modo's platformservice.
The way to run the script is either from the command line, type @uvlayout.lxm to start the macro, or by binding a key to run this command.
To bind a key, open Modo and from the System Menu, select Input Editor. I bound the command to Ctrl-U. To implement this example, click on the Ctrl Modifier and scroll down to Ctrl-U and type in @uvlayout.lxm as in the Image below. If the Ctrl-U key is not displayed in the list and the key has previously not been used, it is currently unmapped. To view the unmapped keys, check the Show Unmapped Keys check box. After entering the @uvlayout.lxm, make sure you press return so that the new command is registered before you close the Imput Editor window.
Now with a mesh selected type Ctrl-U and the following Popup is displayed.
If the model has more than one UVMap make sure that only one is selected if you want to edit these UVs in UVLayout, otherwise UVLayout will not open anything. (At the moment, if you select more than one UVMap, it will try and import both into UVLayout with undefined results - so please select only one for editing)
When Importing back into Modo, make sure that you click on Send in UVLayout before clicking on Import From UVLayout. If you have the Add New Vmap option checked, a new UVmap will be added to the list of UVMaps, if it is unchecked, all of the UVmaps will be deleted prior to importing the new one.
Future Developments
  • Also I'll be adding the commands part of the plugin to the *.cmd file.
  • Performance improvements for exporting.
EDIT: Updated to V1.2
UVLayout1-2.zip
V1.2
Download
 Filename:  UVLayout1-2.zip
 Filesize:  4.33 KB
 Downloaded:  6042 Time(s)
PostPosted: Sun Jul 19, 2009 7:13 pm    Post subject: Reply with quote
Thanks for your efforts! Hopefully you get some feedback for Modo users out there.
Rich-Art
PostPosted: Mon Jul 20, 2009 2:17 am    Post subject: Reply with quote
To bad there still is no Cinema4D plugin..
Peace,
Rich_Art. Wink
JamesH
PostPosted: Mon Jul 20, 2009 12:11 pm    Post subject: Reply with quote
Added a new version 0.2 that allows the existing vmaps to be kept and not deleted. It adds new vmaps with an incremented index if the parameter Vmap is used on import. For example
Code:
@uvlayou.py Import Vmap
JamesH
PostPosted: Fri Jul 24, 2009 5:22 am    Post subject: Reply with quote
I've added a new version 1.0. This contains a .cfg file that adds a form that can be assigned to a key (See first post - GUI heading)
JamesH
PostPosted: Fri Jul 24, 2009 5:48 am    Post subject: Reply with quote
Phil, I'm having a problem getting UVL to exit, I'm creating a file called uvlayout.cmd (the main obj file is uvlayout.obj) and writing Exit to it (Exit is written to the file) but UVL is not closing.
Any ideas ?
PostPosted: Fri Jul 24, 2009 6:03 pm    Post subject: Reply with quote
That should be working ... case is ignored, so "exit" and "Exit" both work.
Try adding "-debug" to the uvlayout command line ...
uvlayout -plugin -debug file.obj
It prints out what files its tracking, and when they're found etc. Normally you'd run uvlayout from a command shell though in that mode so that the output goes to the shell window ... not sure where it'll go if you run it from your python script.
JamesH
PostPosted: Sun Jul 26, 2009 10:48 am    Post subject: Reply with quote
I've added a new upload that fixes a defect and allows individual UVMaps to be selected prior to exporting. I've also added a macro to open the UVLayout popup prior to importing/exporting.
See first post.
I'll also be working this week on getting the commands working if I can find a way of displaying the debug messages.
Cheers
r_knightly
PostPosted: Mon Jul 27, 2009 2:51 am    Post subject: Reply with quote
Peace,
Rich_Art. Wink
step up and sort it out. Smile (Admittedly my latest efforts with max have been thwarted with failure)
JamesH
PostPosted: Fri Jul 31, 2009 7:48 am    Post subject: Reply with quote
I've added a new version, 1.2
New to this release
  • Performance improvements exporting to UVLayout
  • Progress bars
  • Auto calculated temp file locations, just add the location of uvlayout.exe
Rich-Art
PostPosted: Sat Aug 01, 2009 7:37 am    Post subject: Reply with quote
r_knightly wrote:
Peace,
Rich_Art. Wink
LoL I'm not a programmer. I already loose it after 1+1... Very Happy
Peace,
Rich_Art. Wink
garyhanna
PostPosted: Thu Aug 27, 2009 9:06 pm    Post subject: Reply with quote
Is there any reason this would not work on OS X since it is Python?
Gary
JamesH
PostPosted: Sat Aug 29, 2009 1:22 pm    Post subject: Reply with quote
You may have to play around with the path locations and I also use subprocess.Popen, but I'm assuming that subprocess will also work with OSX. If you do get it working, it would be great if you can post any changes you made to the script and I'll update the first post.
Cheers
James.
garyhanna
PostPosted: Sat Aug 29, 2009 2:41 pm    Post subject: Reply with quote
Thanks James,
I haven't gotten it to work yet. The first thing I did was change the path in the script. When I run it in Modo, the UVLayout dialog come up fine. But once I choose export, i get the processing bar but then it errors out. I think it doesn't like the path to UVlayout but I am not sure.
If I get it working, I will post it.
Thanks again for the script.
Gary
JamesH
PostPosted: Sat Aug 29, 2009 9:25 pm    Post subject: Reply with quote
I use the temp path queried from Modo using
Code:
tempPath = lx.eval1("query platformservice path.path ? temp")
then adding uvlayout.obj , .out etc to the end.
What you can do is just add
Code:
lx.out("path : %s"%tempPath)
somewhere in the script so that the path is displayed in the event log, to check it is correct, if this works, then the next step is to make sure that the .obj file is being written to this location.
Goto page 1, 2  Next
Page 1 of 2
