Is there some way to weld blue edges together.
UVDan
PostPosted: Wed Jun 03, 2009 9:44 am    Post subject: Is there some way to weld blue edges together. Reply with quote
My current project opened with a lot of blue edges that need welded to other blue edges. How do I do that?
Lewi
PostPosted: Wed Jun 03, 2009 9:58 am    Post subject: Reply with quote
Hi, you will have to do that in another 3d soft at the moment.
UVDan
PostPosted: Wed Jun 03, 2009 10:45 am    Post subject: Reply with quote
Thanks. UVLayout welds better than the other softwares. I need to do it here.
PostPosted: Thu Jun 04, 2009 4:07 pm    Post subject: Reply with quote
Blue edges indicate seams in the geometry. If the gaps are really really small, then one of the load options will join them up ... I'm travelling at the moment, so cant test which one it is, but its either "Weld UVs" or "Clean". If neither of those works, then you'll need to use your modelling package to fix up the geometry.
UVDan
PostPosted: Thu Jun 04, 2009 5:42 pm    Post subject: Reply with quote
Thanks Cool
