soulrider911
Posted: Thu Apr 30, 2009 11:14 am Post subject: Add cuts to mesh after hitting D to drop into flatten |
I have a mesh that I have roughly cut up. I hit "d" to drop it into the flatten view. However I realized after the fact that I need to add a few more cuts to the mesh. But Obviously I no longer have the mesh available to do so because it is been moved to the flatten view. How do I go about adding more cuts to the mesh??thanks so much
Brady |
Lewi
Posted: Thu Apr 30, 2009 4:51 pm Post subject: |
| Hi there, once your model is dropped to the " UV View " you can still cut and weld with the " C " and " W " keys as normal. Also if you want to go back to the begining you can " Shift + D " to undrop your shells back to the " Ed View ". |
Posted: Thu Apr 30, 2009 6:22 pm Post subject: |
Right after dropping you need to flatten the shells first (either F or Shift-F) and then extra cuts can be made with the C key.
If you haven't watched the videos yet, its highly recommended ...
http://www.uvlayout.com/videos
At the top of all of the movies is a small window that shows what keys are being pressed, so if you cant work out how something was done, look up there for some hints.
